P0702 Error Code: Trans. Control System Electrical
Thank you!
on it that wil fail. It is located on top of the valve body and is a couple hr repair. First and foremost you need to find someone that can retreive the EGS fault codes in order to diagnose properly without spending a ton of money and effort.
Good morning! Thank you for your reply! I found a shop that can retrieve fault codes from the EGS. That will be happening this Saturday. Also, I should have said this in the previous post. I have replaced both Catalytic Converters (Driverside-47,000 miles/ Passenger side 82,000 miles) And the Diverside Converter is going bad already! It is a OEM Rebuilt Converter. I read that it could be about eight different things that are causing the Converters to go bad. Any idea what I should check first? Thank you once again for your reply!
