Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
Wiring My Starter 1969 220 - HELP
Old Nov 26, 2011 | 07:49 PM
Topher39's Avatar
1968 220 4 cyl gas
I have a 1969 220, 4cyl Gas - I received the car with NO starter, found a used starter and ready to install. I know where the main positive cables go, but what I don't know is on which of the small posts the small gauge wires go to.
Attached is a photo of my New/Used starter - the lower (marked "B") has an old white wire (from donor car) the post above (marked "A") currently has no screw to attach to.
My "Stray" wires:
On my car I have a PURPLE that is joined with a WHITE (white goes to a relay on firewall)
Then I have a RED wire with PURPLE STRIPE - I can't find this RED wire with purple stripe on my wiring diagram.
I am hoping you can give me some insight so I can get this on the road again.
Old Nov 26, 2011 | 07:52 PM
Topher39's Avatar
1968 220 4 cyl gas
here is the link to the photo:
https://mbworld.org/forums/e-class-w...ssistance.html
