R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Any of you experince any transmission issues?
Old Jul 24, 2007 | 03:32 PM
mitaka's Avatar
12 E550
I have a new R320 CDI. It is 2500 miles and I am experiencing some tranny issues. First of all when you accelerate there is always a little jerk between 1 and 2 gear sometimes between 2nd and 3d. It is very little almost can pass as normal. After that it is like butter. I decided to try shifting with the steering wheel shifters and keep the car on 1st longer. About 1800 rpm I experience a sudden surge of power and as if as the car is about to downshift but then continues on 1st gear. What is up with that? I also experience a bit of clunking noise in slow moving traffic 15-20 mph if you lift you foot off the accelerator and then reapply it. It almost feels like a clutch that was released too quickly. I brought the car to the dealer and they did a software update and said that they fixed the issue but I think it is even worst than before. Reading some old post I see that many other models experince similar issues. Any feedback will be highly appreciated.
Old Jul 24, 2007 | 04:41 PM
Benz-O-Rama's Avatar
This is a "characteristic" of all 722.9 transmissions across the MB line. Try putting the transmission in "C" mode (not the suspension if equipped with airmatic) and see if it goes away. I bet it does.
Old Jul 24, 2007 | 09:06 PM
mitaka's Avatar
12 E550
Old Jul 25, 2007 | 03:50 PM
RDriver's Avatar
2007 R320
Transmission lurking, jerking, roughing . . . are usually experienced by R350, R320, ML Class and GL CLass. You need to bring your car in for transmission software adaptation and/or readaptation. It may take a few tries to get it corrected. I brought my car in 2 times at 800 miles and at 2,000 miles. Some owners would still experience the rough shiftings following the services. You need to drive your car a couple hundred miles or more for it to smooth out following the software adaptation updates. I did experience rougher shiftings when I first got my car back but soon it all went away and now the car drives smooth as "silk", in either C or S shifting modes.
Old Jul 27, 2007 | 11:00 PM
mitaka's Avatar
12 E550
You are right it is getting better with thime after software update and even better in C mode. Thanks
