R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Aftermarket Radio
Old Jan 4, 2009 | 03:50 AM
chiefmoon's Avatar
R 500
Aftermarket Radio
Has anyone swapped out the stock nav for an aftermarket system? I just want to know if there would be incompatibility issues with the HK speakers and the stock amp?
Old Jan 12, 2009 | 07:17 PM
BigHomie's Avatar
R350
How To Add Boom To Your Factory System
I'm not sure if tampering with your factory setup is a good idea (compatability issues). You might want to check into powered subs. In particular, I purchased 2 Infinity Basslink (200w each) subs from crutchfield.com for my R350. Ran power to each sub from battery under front passenger seat. Used factory subs' (in spare tire compartment) left and right channels to run signal seperate to each sub. Mounted them on back of the 3rd row seats facing rear hatch for bass reflex (use enough wire to still be able to fold down rear seats for cargo flexibility). For convenience, they came with wired remote controls I mounted on my drivers' side side dash to customize sound after setting both Basslinks to half volume, zero bass boost, and lowest frequency cut-off.
The Basslinks combined with the 440w Harmon Kardon factory system gives me clean sound with enough power to rattle my rear when I want to! Help this helps you out...
Old Jan 19, 2009 | 06:40 AM
chiefmoon's Avatar
R 500
it isnt and issue of more bump but a technology issue. we have a pioneer f700 nav system from another car and i just wanted to know if anyone had changed theres so i would have an idea of cost, troubles etc..... but i guess judging from zero responses no one has changed out this radio. do your speakers take up a lot of room?
Old Jan 27, 2009 | 11:13 AM
ZBoater's Avatar
2014 E350 W212
I had one of these installed:
http://www.kenwoodusa.com/Car_Entert..._Video/DNX7120
No problems. The installer had to do a custom frame, and it turned out nice.
Old Jan 27, 2009 | 01:10 PM
silverspecial's Avatar
2007 R350 - P01- Black on Black, 2008 Toyota Sienna Limited
Pics please!
Old Feb 2, 2009 | 10:16 AM
BigHomie's Avatar
R350
Nah. Each unit is only 1 cubic foot.
