R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
TPMS problems!!!
Old Jan 9, 2009 | 01:39 PM
thomazz321's Avatar
r350
TPMS problems!!!
Just had my two fron tires changed but now when im driving fast i get the tpms inoperative message. does not happen when driving slow. Any ideas to what it could be?
Thank you.
Old Jan 10, 2009 | 09:14 AM
melvinh's Avatar
R350
Check and make sure your tire pressue is correct! Then, you need to re-activate the tire pressure sensor in the center information display. You push the left end button until you see "tire pressure..." re-active press "-" and "+"... if i remember correctly. Please check your owner's manual. Hope this helps.
Thank you.
Old Jan 10, 2009 | 01:48 PM
lkchris's Avatar
'10 CL550, '12 GL550
IF the message is truly "TPMS inoperative," then your sensors were damaged or removed.
Old Jan 10, 2009 | 03:59 PM
JTReeves's Avatar
2007 R-500
I'm with Kent. I've not seen that message before, only "adjust tire pressure." I recommend revisiting the shop that repl'd yr tires and ask dor an explanation.
JR
Old Jan 12, 2009 | 11:37 AM
thomazz321's Avatar
r350
Thank you guys. i've tried to reset it but it comes back on after i drive fast. i guess i'll take it to the dealer.
