R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Foglights H11 80W
Old Mar 8, 2009 | 11:30 AM
dewdaltz's Avatar
02ML320/06R350
Foglights H11 80W
what would happen if I use this on my foglights.
Old Mar 8, 2009 | 12:55 PM
AsianR350's Avatar
08 R350, 12 Mercedes R350
It might cause the wire to melt or even on fire. I have seen quiet a few.
You need heavy duty harness that connect in series with OEM harness.
I used H7 NOKYA Hyper Yellolw 2500K 70 Watts bulb w/ heavy duty harness and have no problem so far.
Old Mar 9, 2009 | 07:25 AM
JTReeves's Avatar
2007 R-500
Plan B, install a relay between stock wiring and light fixture. Run higher guage wire between the relay and the bulb socket. Light switch activates relay; relay activates bulbs.
Old Mar 9, 2009 | 12:45 PM
AsianR350's Avatar
That is good point just a bit more work.
I beleive a live positive voltage that connect to bulb end must run from battery or some sources and OEM positive wire go to relay.
