grippy brakes approaching stop
hi guys,
do you guys know what causes the brakes to be grabby and NOT release smoothly right before the complete stop, or right when I'm about to accelerate? the brakes work fine, but right at the end point - the final inch, i usually try to stop the car smoothly...and either there's still too much torque w/ engine at idle, or the brake bads are not smooth? (the brakes are only about 15k miles old and they work great).
p.s. i'm having this problem only on the R500, but do not have this problem on my S55 or E320 cabriolet.
PL
PL
R350 4-matic
Depending up on brake pressure you're applying there is a brake power boost feature and that could be it. Also when first accelerating away, if there is ANY type of incline, you're brake hill-assist is engaging and that is what you're feeling.
Btw, I played around with the C/S setting for transmission and found out it's MUCH better on the C setting. On the S-sport setting, it's definitely much more grabby - right near the full-depressed brake mode. Although I like the S-mode for spirited driving, going to switch to C-comfort for a while and enjoy the smoother complete braking.
PL
PL
Generally speaking, all brakes get more "grabby" as you slow down 'cause it's a law of physics that friction increases with the inverse of speed. Your smoothest braking will occur as you decrease pedal pressure as you come to a stop--try it.
OTOH, given how poor I think the brake feel is on my GL and how likely it is R-class components are the same or nearly so, some of this is likely due to Mercedes supplier design.
actually, it isn't merely physics as i'm comparing the way the car drove 6 months ago when brakes were newer vs. now. if it did not grab before and grabs now, i think something has changed. from my observation, only 2 changes - older brakes, and I started using "S" transmission setting vs. the "C" setting. indeed, when I switched back to "C" setting, the brakes were indeed smoother.
PL
PL
R350 4-matic
PL
PL
