R 320 CDI Engine Rattle
Mercedes R 320 CDI Sport 4Matic
I am experiencing a rattle noise until engine is warming, once is warm the rattle goes away until next morning.
I get the same rattle when i Reverse for some reason but not at all times.
Thank you for any comments and help to identify the above problem.
2006 Mercedes R 320 CDI 75k
I have an 08 R 320.
But - the very same happened, when it is very cold out (less than 10 degrees) and the car is warming up - there would be a vibration noise.
I narrowed it down to a heat shield over a muffler. That "tinny" rattle would go away, but it was there.
In warmer temps, not there at all.
Good luck.
Good luck.
I have an 08 R 320.
Good luck.
Good luck.
This morning I have tried to find the vibration noise around engine compartment but I can't identify where is comming from and once I am around the engine I can not hear anything it seems that I can only hear it when I am inside the car with all the doors and windows closed.
Need to do more inverstigation next mornging
