Smell when turning on AC
R350
Need some advice on how to remove the smell coming from the vents when turning on the AC. Replaced the cabin filter but smell is still present.. Thanks
2008 VW GTI
Its probably built-up condensation on the coil getting mildewy. Try turning off the AC a few minutes before you shut the car off. This will warm up the coil and hopefully stop water from condensing on it.
2008 ML350 4matic
My dealer sells a small spray can of "Frigi-Fresh" to spray into the fresh air intake to eliminate that smell. It is an anti-bacterial that leaves a clean smell in the car for a few days then neutral. Works well for that exact smell.
M/B of St. Charles Illinois.
6.95 a can....not bad. The instructions are to blast the A/C full cold full fan for several minutes and spray into the intake. Im sure Lysol or something along those lines will suffice as well.
http://www.ac-evaporator-cleaner.com/
