New LED strip Turn Signal lights Mod.
Hi AsianR350
- Did you remove the other sideview red leds you had mounted on the top of your taillights? I was going to do the samething I thought it look good was there a problem later on?
Both were burned out for some reasons so I removed them.(I guess that it was not tight seal from water or overcurrent that caused it burned out)
