R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
R350 Tailgate Failure
Old 04-15-2011, 12:16 AM
AChernay's Avatar
E500 and R350
Hi, new to the site but already appreciate and have benefited from the posts. Saved a ton by reading posts on replacing climate blower fan! Next up on wife's R350 is the tailgate. Has anyone experienced a power tailgate motor failure? That is what I think has happened but want to make sure before ordering parts. When tailgate open/close function is started, you hear the mechanism engage, the lock unlock and then nothing happens but a grinding noise. The tailgate does not open or close, just the grinding noise. Any insight will be greatly appreciated. Thanks
Old 04-15-2011, 08:16 AM
gforaker's Avatar
2015 Audi S4, 1982 Fiat Spyder, 2010 R350, 2013 E550 Cabriolet
Lots of people here have reported taking it to the dealer where the fix is just an adjustment of the lock mechanism. Not to say that it couldn't be a motor, but that doesn't seem as likely.
Old 04-15-2011, 10:02 AM
AChernay's Avatar
E500 and R350
Thanks for the reply, truly appreciated. Will start there.
Old 04-18-2011, 01:39 PM
shakabra's Avatar
06 R500
Hi. I'm not sure if this is the same thing but last week my tailgate failed to open. It tried to open just slightly, then came back in. I tried it a few more times, then stopped so I didn't burn out the motor. I read a thread that mentioned keeping everything clean and lubed and that did the trick here too. I opened the hatch via inside/ manual lever. Pushed tail gate up a foot then opened it all the way with key fob auto switch. Then I cleaned and lubed everywhere. It now opens/closes perfectly. Thanks for the previous threads on this.
Old 04-18-2011, 01:47 PM
AChernay's Avatar
E500 and R350
Thanks for the additional info. Did you disassemble any parts, or clean and lube what was readily visible?
Old 04-18-2011, 01:50 PM
shakabra's Avatar
06 R500
No I didnot disassemble any parts. I cleaned and lubed the rubber side stops on the door and body, the entire seal, the locking mechanism and lubed the hinges as best I could with silicone spray.
Old 06-03-2012, 05:59 PM
joeboch348's Avatar
R350 X5 4.4 67 alpine
I'm having the same problem. one day it works then next i have to reach in to open it manually. I cant see lubing the lock helping this. is there possibly a solenoid not unlocking the lock?
Old 06-10-2012, 08:04 PM
efzauner's Avatar
2005 C240 2011 R350
there are many posts on this issue. Do your homework.
Basically the dealer will start by charging you for a latch adjustment not under warranty
Then a latch replacement under warranty, then more lift mechanism changes. Dont let them charge you for incomplete fixes. I told my dealer I would pay for the latch adjustment on the condition that if it did not fix the problem that they would reemburse mefully. Dont let them push you around. The real liftgate is a known problem.
Old 06-12-2012, 09:44 AM
OldMBGuy's Avatar
2002 E320 4matic Wagon
We went through all the fixes and only one thing ever worked for more than a couple of months. Set the liftgate to open all the way. It's a PITA if you have a low garage ceiling, but it seemed to work for us. Can't tell you why.
Old 06-18-2012, 09:45 AM
pacoman's Avatar
2008 R350 4-matic
I had the exact noise and problem as you described and the dealership replaced the lock mechanism and it solved the issue completely. Cost was $600.
Old 07-30-2012, 01:19 PM
joeboch348's Avatar
lift gate
how do you set the liftgate to "open all the way?
Old 07-30-2012, 03:36 PM
joeboch348's Avatar
OK, I took the tailgate trim panel off. The problem with mine is the lock doesn't unlatch. So I would have to reach in from the back seat and pull the handle to release it. Took 5 mins to pull the panel off. 2 mins to unscrew the 3 torx screws to remove the lock assy. about 15 mins to replace the lock. Cost $300. Be sure to buy the plastic clips that hold the trim panel on too. works great now.
Old 07-30-2012, 06:28 PM
AsianR350's Avatar
08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
I am glad you did it yourself and save the labor charge from the MB dealer.
BTW, what is the part number for the plastic clips? (I plan to take the rear panel off to install the rear B/U camera).
Old 07-30-2012, 08:10 PM
joeboch348's Avatar
I should have written both part numbers down but I didn't I did it during my break at work and threw everything out. Sorry. I just asked the dealer parts guy. Back up camera?? Spill the beans! What's the deal?
Old 06-12-2013, 07:34 PM
bypass's Avatar
R320 cdi
New lock mechanism fixed mine
Just wanted to add to those who have commented already that a new lock mechanism (bought mine from KO Performance for about $250) fixed our tailgate closing (or rather NOT closing) issues. Like others our tailgate would close but not 'lock'. Also, the new locking mechanism seems to have cured the tailgate not closing all the way when the height limiter was turned off. Before hitting the close button would cause it to close only about 6" and it would then stop. We'd have to hit the button again to get it to close completely.
A really easy fix for those willing to try and I would suggest buying some of the yellow body panel clips in case some break when removing the panel to access the mechanism and emergency release cable.
Old 06-12-2013, 09:05 PM
AsianR350's Avatar
Here is the real deal. I do a lot of parallel parkings and back in and it saved my rear bumper from scratches or hot any car behind that rear mirror can not help to you see.
Note:My back up camera set up to be turn on at at all time even while i am driving forward.
Old 06-12-2013, 09:08 PM
AsianR350's Avatar
Here is the real deal. I do a lot of parallel parkings and back in and the b/u camera besides the parktronic saved my rear bumper from scratches or hit any car behind me that rear mirror can not help you see what next to the bumper.
Note:My back up camera set up to be turned on at at all times even while i am driving forward.
Old 07-05-2014, 12:21 AM
donyo's Avatar
2012 c250
r 350 lifgate do not close
the tail gate of my car is not closing , it open fine but stay up i have to manually pull it down , and the it lock fine....
Old 07-05-2014, 11:08 PM
supernsx's Avatar
2011 C300 4matic, 2015 Porsche Macan S, 2006 R500 (sold)
I had something similar and end up with the battery doesn't have enough juice to pull the lift gate down. After I replaced the battery, problem went away.
Old 07-07-2014, 04:18 PM
user 823908234's Avatar
Do a search on this forum. Lots of info about the tailgate issues, probably the biggest issue with the W251.
Old 08-31-2014, 10:44 AM
ac.will's Avatar
R-350
I have had this issue,and am having it now. Previously they told us the "computer needed to be reset at a tune of $89.00. Now the door will not open at all. Not with the Key FOB, using the manual opener on the outside of the vehicle or the manual opener on the inside of the vehicle. I believe that would constitute as a huge safety issue, if the rear door was our only option to exit the vehicle.
Old 09-11-2014, 02:07 AM
Yule Gurreau's Avatar
MBZ R-350
R-350 tailgate failure
Cann't get the tailgate opened-opening mechanism makes noise, tailgate moves 1/4 of an inch and locks back. Please advise,
Thank you,
Yule
Old 09-23-2014, 07:49 AM
Flamer97's Avatar
2009 R350
Yule, you describe the exact same problem I had on my 2009 R350. I took it to the dealer (not under warranty) and they replaced the tailgate lock/latch assembly part number (164-740-07-35) for a whopping $883.55 with $480 of that being labor. They also used 14 trim clips (part number 000-991-63-98-64).
I do not think I could have done it myself, maybe others have...but here's a link to what the part looks like. Rear Liftgate Lock/Actuator.
Old 09-23-2014, 08:10 AM
Flamer97's Avatar
2009 R350
Yule, I was curious and found this video on youtube about replacing the latch on a M Class... it is the same part number so maybe this will help.
Old 11-08-2015, 12:51 PM
kcherrix123's Avatar
R350
Lift gate won't raise all the wat
The lift gate in my 2008 R350 opens and closes fine, but when it opens, it only goes 1/2 the way up. Just enough to bump your head on it. Our Toyota has a button that lets you reset the lift gate track. Doubt there is anything that easy on the R350. Any suggestions?
Quick Reply: R350 Tailgate Failure
