R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
2007 R350 Transfer Case and front and rear Differentials fluid change
Old May 29, 2011 | 11:55 PM
2007R350guy's Avatar
2007 R350
I hear that the transfer case fluid needs to be changed preferrably at 39k, but will do it next week at 57k for $159. Does anyone know if the front and rear differential fluids also need to be changed. Is the transfer case hard to get to?
Thanks.
Old May 30, 2011 | 12:06 PM
smokersteve's Avatar
06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
Transfercase and diffs are easy, straight forward.
What are the fluid part numbers? Does MB ONLY use this fluid?
Old May 30, 2011 | 12:34 PM
2007 R350
I have an import garage that I use now for my maint and repairs. I'm not sure what fluid he has selected. Is the transfer case easily accessible? I know the dealership charges $240, but this guy will match the $159 I found at another MB Dealership. The differentials are not included in this price. Thoughts?
Old Jun 2, 2011 | 10:02 AM
2007 R350
Went in to my import service shop in Naperville, IL for my oil change and also had the Transfer Case and front and rear Differential fluids changed. The Transfer Case on the 2007 R350 is accessible from under the car on a lift. I was originally told that multiple parts would need to be removed in order to access the TC. Not true.
Old May 3, 2013 | 02:13 PM
What fluid goes in the transfercase?
I just changedmy front and rear diff. I used VALVOLINE 15W-90 FULL SYN.
