R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
HELP - '06 R500 Suspension riding extremely high on one side
Old Apr 5, 2012 | 11:04 AM
joeboch348's Avatar
R350 X5 4.4 67 alpine
Car is fixed, paid cash so I got a discount! The bag itself was 450 from MLB. He has g
Had bad luck with the aftermarket ones. 1 yr guarantee. The guy is strictly German car repair.
Charged 100 to diagnose and 80 to install.
FYI he says 1 bad thing on the 06 r350-500. Cam shaft gears are pressed on and are a problem$6000 repair! He is expecting a class action against MB.
Old Apr 5, 2012 | 11:33 AM
2006_MB_R500's Avatar
2006 R500
Great, I'm glad you're riding level! I have to take mine in shortly.
There is a pending class action suit in the U.S. due to the camshaft issue, but all the articles and posts I have read note it pertains to the 350, not 500.
Old Apr 5, 2012 | 04:54 PM
2006 R500
My car is level! They couldn't find anything wrong with it, so they "re-calibrated the suspension," which took 2 hours. Mechanic noted the following on the invoice:
"Checked for any air leaks, soaped down air bags, lines and fittings, no leaks found. Hooked up to computer for diagnostics. Performed system test, air bags inflated and deflated. Performed rest procedure and tested operation of suspension. All tested good. Let sit in shop for 15 minutes, suspension stayed level. Test drove vehicle, no issues noted."
I noticed a big difference as a soon as I saw the car. Guess I got off lucky this time. *crosses fingers*
Old Apr 5, 2012 | 07:37 PM
joeboch348's Avatar
Lucky you. I was hoping thats all i needed. What was the labor charge? Should be free
Old Apr 5, 2012 | 07:44 PM
2006 R500
Free would have been nice, but this a Benz dealer. The `Diagnostic Hookup Charge` was $50 + straight time for 1.68 hours labor to perform the diagnostic + tax = $231.36. I believe their labor rate is $95 per hour, which is better than the two dealers in the city (Ottawa), which is $115 per hour.
Old Apr 5, 2012 | 08:54 PM
joeboch348's Avatar
They made more in labor than my guy did changing the bag. Oh well hopefully were both all set for a while
Old Apr 6, 2012 | 08:30 AM
  #32
2006 R500
LOL, no doubt. But it should have only taken an hour or so to change the bag, which is less time that what they spent on mine. I'm not sure why a $50 charge applies just to hook the car up for the diagnostic but it is what it is.
Hopefully it will be okay for a long while. I may convert to the coil suspension when things start malfunctioning as once they start they don't seem to end, whereas with the coils, once it's done it's done. Won't have to worry about the bags, sensors, compressor, etc. I looked up the parts needed to convert to coils and it runs around $350 excluding the spring compressor. In my case there would be labor to have my mechanic do the work, and hopefully he would have a suitable spring compressor as they run about $278 on Ebay for the W251. The guy that did the conversion on his own R said the ride is exactly the same, it just doesn't compensate for difference in load weight. Food for thought.
Old Apr 6, 2012 | 09:33 AM
  #33
joeboch348's Avatar
I like the air bag system. I have it on my X5. Bought it new in 02 and have had no problems. Nice for loading the vehicle up or towing. I wouldn't go to coil springs. Now I'm worried about the cam gear
Old Apr 6, 2012 | 10:38 AM
  #34
2006 R500
I like it too, but if it's going to cause chronic, expensive problems I would go with coil. I don't tow anything and don't usually have a lot of passengers or haul things around. Hopefully I won't have to make that decision for a long time. The cam gears do seem to be an issue with the 350's, I wonder if there is a usual mileage when they tend to start going like the air bags (around 70k miles). I'm sure not every one of them experiences the problem, you may be one of the lucky ones. Time will tell I guess.
Old Apr 6, 2012 | 12:52 PM
  #35
joeboch348's Avatar
I just purchased mine with 117k on it. Im hoping it already happened or isnt going to. I wont tow with it either but bought it to fill with kids and cargo
Old Apr 6, 2012 | 01:10 PM
  #36
2006 R500
You should try and get a copy of the work that was done while under warranty. The Benz dealer I use got a copy for me. All they needed was the VIN.
I'm glad you mentioned this topic, I just checked mine and one of my air bags was replaced under warranty in 2010 as it was leaking. Car only had 41,889 kms on it. In 2009 a "position sensor, crankshaft electrical fault" was also repaired. In total, 30 items were replaced/repaired under warranty. Yes, 30, and all before the car had 43,000 kms on it. And I'm glad, that's probably why I haven't had any issues until the suspension problem that was fixed yesterday lol.
Old Dec 3, 2013 | 09:43 AM
  #37
pratkanaga's Avatar
R500
Question
Originally Posted by aljajoly
No computer required guys, I changed it al myself and everything works fine.
I know this thread is old and please also ignore my trivial question on this. My R500 was quite low on the passenger side last week. I wasn't sure if I could drive around with it, hence left the car in the garage over the weekend. When I looked at it this morning, rear suspension was back up on the passenger side, however the driver side is still an inch or so higher. The temperatures dropped suddenly below 0 where I live over the past two weeks. Then the tire pressure monitor light came on even though tire pressure was fine, followed by the suspension issue. My concerns are;
Is it safe to drive around for the time being, as it seems to have raised the passenger side a lot more this morning. Also is it likely this is a result of the cold weather and eventually it might fix itself (as dumb a question as it sounds)?
Thanks in advance.
PK.
Old Dec 3, 2013 | 04:22 PM
  #38
PeteInLongBeach's Avatar
2007 R320 4matic / Airmatic
You likely have a slow leak in one of the air springs. It appears to be more common for this to first manifest itself when the weather gets significantly colder. It may get better & worse with temperature changes, but it will not fix itself.
If these are the original air springs on your car, they are due for replacement anyway, so I would just replace the 2 on that end of the car with Arnott aftermarket air springs, as they tend to go bad in pairs within relatively short succession.
Old May 29, 2015 | 11:35 PM
  #39
mybenz43's Avatar
2000 s500
I have a 2006 R500 with front and rear air springs. The right side of my R500 is lower than the left side. If the rear air bag is leaking will it also cause the front of the car to be lower on the same side?
Old May 30, 2015 | 06:49 AM
  #40
josworth's Avatar
2006 R350
Possibly. If one bag has lost pressure it will cause the whole car to lean to one side. Ours did that when it was failing. The front would lean with the back.........
Old May 30, 2015 | 10:34 AM
  #41
mybenz43's Avatar
2000 s500
Thanks Jeff. Now all I have to do is find out if it is the front or rear leaking.
Old Nov 3, 2015 | 05:28 PM
  #42
pagesk's Avatar
740iL, R500, Jetta
tire is over heating
Originally Posted by apjdjd
I have an R350 and I have been having the same problem, sometimes it is fine and others not, I have noticed that when the tire pressure warning comes on this happens, don't know why.
Anyone?
The load is transferred to the front wheel on the opposite side and it is getting hotter and thus has a higher pressure than the other tires so the pressure warning goes off.
Old Jul 17, 2016 | 10:17 AM
  #43
pagesk's Avatar
740iL, R500, Jetta
After 5 years of the erratic behavior of the air spring system, my now rides on coils.
Old Apr 12, 2017 | 03:28 PM
  #44
Ricki's Avatar
Scania 620
My 620 got same problem
hi mate just wondering if you got that sorted my r620 12 plate got same problem any chance u could give me any clue I can't find what it is
Old Apr 13, 2017 | 08:12 PM
  #45
JonMac's Avatar
2002 C240 (W203) 2007 R500 (W251)
Hi Ricki ! welcome to the R class though i was taken aback with your R620 (?) and it's a truck?
