2011 door panel removal?
Thanks! Great looking forum!
https://mbworld.org/forums/r63-amg-w...to-thread.html
For the front panels, you have the one bolt is hidden behind the lock/unlock button. In order to get this button out, you have to pull out the thin black trim that seprates the lock and unlock functions- this allows you to pull the button assembly out. the screw is hidden behind it. Then you've got to work out all the clips surrounding the trim and pull the door panel up, as there's a hand that sits onto that metal handle/mount that you see in the center of my door on post #24.
If you need to do the rear panel it's the same concept except the one screw is hidden behind the tweeter (right in front of the chrome door handle). You just have to remove the mesh grille and then you can access it.
Hope that helps! What are you trying to accomplish by removing the panel?
warranty is over in 1500km....lol!thanks very much! that lock switch had me baffled for the longest time. wtf where they thinking? lol!
The subs are hooked up to a JL 750 watt amp. The door speakers are all hooked up to the stock amp (per the previous owner).
If I wanted a 100% custom setup all I'd need is a JL 4 channel 600 watt amp, but I find the sound good enough right now to warrant not spending the extra money on another amp and getting that all hooked up.
What are you thinking about doing?
