Is it possible to fit Facelift LED tail lights on a R-Class from 2008 ?
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Yeah it doesn't work too well because the facelifted lights are shorter than the previous design so you'll be left with an unsightly gap. Even if you ignore fitment issues, you'll then run into problems with the rear SAM which will probably need to be changed out to a newer one to talk to the new lights. So it's doable, but will require lots of work.
