R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Anyone upgraded their Comand Navi to the new Comand NTG 2,5 HD on their R-Class
Old Jan 3, 2014 | 05:34 AM
lacour's Avatar
R280 CDI
Will it demand any mods or is it just plug & play when you have a excisting Comand system ?
Old Mar 4, 2014 | 04:37 AM
Kingpin!'s Avatar
R350 & R350
I have done that.
In my case I had the prewired phone cradle in the armrest, do you have that? If so it's fairly easy but of course it depends on how used you are to such projects.
I bought a NTG2.5 unit and a conversion kit with all necessary cables (cost a bit more but I knew everything was there). Just hooking up the NTG2.5 and replacing the old unit is easy but you have to remove one signal in one of the connectors (if I recall correctly it was the antenna amplifier power). After that you simply connect the cables from the conversion kit and you can boot your new unit. Also, (again if I recall correctly) you will not get more bands than FM (does anybody use anything else though?).
The more complicated issue is regarding the microphone(s). You have to connect a new cable to the unit which will replace the current microphone cable, that step requires some removing of panels etc.
Hope that sheds some light!
