R320 CDI Exhaust Leak-Help
Gents,
I found an exhaust leak just behind the oil filler cap on my R320 CDI. I can hear and feel the exhaust come out but not sure where to go from here. I'm a DIYer and would like to try to fix this myself. Check out the attached pic. The leak is right below the black plastic braided hose. If you look close down in the little cavern there it seems slightly damp.
Any thoughts? Thanks in advance.
Not sure what my next step is.
2008 R320 CDI, 1987 560SL
Do you have any error codes or a CEL popping up?
I'm wondering if maybe you have a seal failure on that injector, and you're getting air escaping from the cylinder. It should give you a CEL, but I'm not sure what the compression loss threshold is before that happens.
