What did you do your R Class today?
I put them on mine because I was paying a lot for tires and only getting around 25,000 out of them and thought what's the point. My tire guy recommended I try the Sailun. I have been able to get almost 40,000 out of them so far. I will replace them with the same soon, I just wish they were a little quieter.
Those BFG's still had a lot of tread, they were just out of round.
I checked the turbo to see if it was spinning freely - no noise and good movement. Then checked the actuator arm to see if it was sticking at all - no problem there. Then I took off the turbo actuator and opened it up, it looked good inside, but after testing resistance on the terminals and soldered connections, I found one connection was broken. I re-soldered it and put it all back together, and all was good again.
Here's the culprit:
Here's the culprit:
Cheers
A BMW hit me in the Lowes Parking lot a couple weeks ago. Not significant damage, but scratched up the wheels real bad. I'm hoping her insurance just gives me a check and I can have a friend strip the wheels and powder coat them flat black..
Had my indy do all but O&F and Nokian WRG3s
serpentine belt tensioner rollers
plugs
air and cabin filters
fixed transmission cooler hose leaks
full transmission fluid flush and filter
differentials and transfer case fluids
front pads and rotors
flushed brakes and power steering
lubed pano roof and all hinges
Hopefully Im good for awhile
Including tires, parts, and labor cost was about 1900
Sourced parts from rock auto, amazon, and ECS
Car is a joy to drive
Had the transmission fluid and filter changed out and drained and put fresh fluid in both diffs since there was no record of this ever having being done in the service records provided with the car. My trans guy said the fluid looked very good and free of any metal shavings and same goes for the diff. I wasn't having any issues just preventive maintenance. Total cost out the door $340.
I did just do it's Service D (found a new merc indy who's great) and he found a slight noise (not noticeable from cabin , only if you're standing outside right at the engine bay listening) that turns out to be the idler pulley which my warranty covered so thats all good.
And installed chrome step plate for the rear bumper over the weekend. Found it on ebay and i always liked the look but note for anyone, the standard bumper would require 'modifications' to fit them. I dremeled the step plate instead to fit (and broke off all the attachment tabs) and removed a bit off the inner edge but it looks good ... i'll get a couple of photos up ... fixed with 3M double sided.
