R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
06 R350 Battery Drain-need help/schematic
Old 01-05-2016, 09:32 AM
mspencer's Avatar
2006 R350
About a month ago I get a call from the wife as she is leaving work and she says her car won't start. She said lights are dim and when she turned the key she just heard a click. I knew the battery was several years old and just assumed it went out. I go by parts store and pick up new battery and replace it. All seemed to be fine until Sunday. She goes out to car and yet a dead battery again. I jumped it off and we drove it for an hour or so and came back home. Monday morning it was dead again. I hooked up charger and battery tested fine and charged. I put ammeter on battery cable leading to the fuse block under seat behind battery and with key out and no lights on it is reading 7-8 amps. It is coming from the wire that is connected to F82. It appears that this may be feeding another fuse block. Does anyone have a schematic or know what F82 is feeding? TIA.
Old 01-05-2016, 12:58 PM
AsianR350's Avatar
08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
There is a fuse block on the right side of the spare tire.
Old 01-05-2016, 01:33 PM
mspencer's Avatar
2006 R350
Thanks. I will check tonight and see if that is what it is feeding.
Old 01-06-2016, 09:18 AM
mspencer's Avatar
2006 R350
I checked last night at it was pulling 3-4 amps with no key and everything off. I did determine that the wire I had questions about was feeding the rear fuse block. I determined that fuse 25 in the rear block was pulling about 2 amps. I think this is the radio fuse. My question now is the radio/command unit controlled by the front SAM? I disconnected the rear SAM and noticed no change in the amperage draw. Where is the front SAM located on an 06 R350?
Old 01-06-2016, 02:09 PM
efzauner's Avatar
2005 C240 2011 R350
SAMs seem to be a popular cause for this... on my previous 08 320 it was the rear parking/proximity detector sam that was the culprit... Left me stranded at 2 am at -30C at the airport...
Old 01-07-2016, 08:33 AM
mspencer's Avatar
2006 R350
One interesting thing I found out was that my wipers worked with key on in position 1(engine not running) but with the engine running they did not work. I know the fuses/relays are good because if not they wouldn't work at all. I also noticed that even when both the front and rear SAM disconnected the amperage draw was still there. I found out that the relay #63 in the rear fuse block was always energized. I pulled the relay and the fuse #25 and the amperage draw went away. Does anyone know what relay 63 controls and is it supposed to be energized all the time?
Old 12-14-2017, 06:44 AM
Please&thankyou's Avatar
R350
Question
I know this is a year old, but any resolution to your question and problem?
Old 01-17-2018, 11:51 AM
RobR350's Avatar
2007 R350 LSE
I just suffered a dead battery which I am putting down to winter cold and I will get a new one, but as the car tends to humm away all the time when on I am bit concerned something like this might happen as its a new car (to me)
Old 01-23-2019, 06:31 AM
RobR350's Avatar
2007 R350 LSE
Updated. I have a brand new battery now, and the car still sometimes get dead battery when left a little while.
this morning was dead yet it was driven about 2 days ago.... very annoying
Old 02-19-2019, 09:53 AM
RobR350's Avatar
2007 R350 LSE
hello, i want to try and do a drain test by popping fuses etc. is there a fuse box schemtaic anywhere that I can use to find out what the fuses do if I found the culprit?
Cheers
Rob
Old 02-20-2019, 01:58 AM
adding audio's Avatar
1971 amc gremlin
https://www.pierrelevaillant.me/post...-r350-fuse-box
http://www.mercedesmedic.com/fuse-r-...diagram-w-251/
http://travelersunlimited.club/merce...-fuse-diagram/
https://motogurumag.com/image/XxeoGz/
test amp under driver seat , to see if condensation , moisture got inside amp and causing parasitic drain.
if yes
remove amp
dry out the seat well pan area where amp is installed too
clean off outside of amp .
open amp , clean off electrolysis white build-up off insides of amp and amp cover
thoroughly dry amp , wipe down with rubbing alcohol , to clean off any condensation mineral deposit build up.
and re-install and re test for parasitic drain ?
leave desiccant packets near obvious amp chassis moisture spot when re install to absorb moisture ?
RobR350 (02-21-2019)
Old 02-21-2019, 12:49 PM
RobR350's Avatar
2007 R350 LSE
Thanks is it easy to access that amp? I also heard about the seat modules having issues and wanted to unplug mine to see if it stopped the parasitic drain but I couldnt get under the seat very well!
Any tips?
Old 02-22-2019, 04:23 AM
1971 amc gremlin
basic amp access
Old 02-22-2019, 04:37 AM
1971 amc gremlin
when doing parasitic drain test with dmm and pulling fuses while checking meter .
you will know if it is the amp or seat wiring , that is causing battery drain
because when you pull that fuse of the culprit causing the drain .
the dmm amp draw meter reading will drop down to where it supposed to be , to around .03 -.06 mili amp draw ,
telling you if it is seat or what ever fuse it is. ,, that is in the line with what is draining battery and needs fixing.
make sure all doors , hoods and trunk are closed or that pin switches for what you open are secured,
so car does not wake up and give you any false positives while doing parasitic drain test . ,
i did find this seat video
but do not know if this applies to your situation..
Quick Reply: 06 R350 Battery Drain-need help/schematic
