Where is the satellite radio control module??
I have been driving my car around for years with only FM 1 station working. I can connect my phone and play music with iTunes. Navigation works. Originally, I got the "Device Unavailable" message after a battery drain. Dealer wants $3000 to replace system. I have seen the thread under the ML model that said others had this issue and were able to resolve it by unplugging the control module for a few minutes to reset it. I want to find my control module to unplug it and see if that works but I cannot locate it. Does anyone know where it is on a 2009 R350??
It sounds like your head unit is defective. There isn't a separate control unit for the radio, it's all integrated. You can try pulling out your head unit and leaving it unplugged for a few minutes.
How about remove and plug back the fuse #F25(30AMP) for the COMMAND/DISPLAY in the rear trunk.(spare tire) to reset it.
https://mbworld.org/forums/r-class-w...play-fuse.html There is an antenna splitter for radio and NAV behind the driver seat and under the carpet. I am not sure it has something to do with it. Mine did not come with the NAV, so I installed the NAV, I had to buy the antenna splitter to split between radio and NAV. |
That makes even more sense.
"There is an antenna splitter for radio and NAV behind and under the carpet."---where exactly??
https://mbworld.org/forums/m-class-w...available.html
This thread is what I was reading regarding the control module, which I cannot locate on my r350. Frustrated! Thanks for any help!! |
Deleted post
I'm thinking here or here:
https://cimg2.ibsrv.net/gimg/www.mbw...c29299b3b7.png |
It's actually the Tele-Aid module
Part #'s 1669003400; 2218700826; 2218700926; 2218708726; 2218205226; 2048202085 The location: https://cimg5.ibsrv.net/gimg/www.mbw...980e4dfa58.png From: http://www.justanswer.com/mercedes/4...isconnect.html |
jsnowden - Any resolution on this? My wife's 2010 R350 just started displaying "Device Unavailable" for Radio, Sat Radio, etc. The only audio we can get is from the CD player. I found the same ML thread as you and was hoping the same un-plug procedure would work for us.
Originally Posted by mk2tmr2
(Post 6979049)
Add me to this as well! 2009 r320 bluetec...battery died and had to get a jump start
everything works but radio "Device Unavailable" I also read the other threads and now I'm look where I can find the "box" to unplug and re plug all the fiber optic wires mentioned... If anyone can help out with a step by step guidance ...it would be greatly appreciated! |
Originally Posted by danbokem
(Post 7082793)
everything works but radio "Device Unavailable" I also read the other threads and now I'm look where I can find the "box" to unplug and re plug all the fiber optic wires mentioned... If anyone can help out with a step by step guidance ...it would be greatly appreciated! Looking for answers. |
On that last picture, it says left rear footwell which to me means behind the drivers seat. However, the picture looks like its behind the passenger seat. Can anyone confirm? Also, did this fix your problem?
Looking for modules on 2012 R350.
Originally Posted by R350NYC
(Post 7334485)
Can someone help and let me know where the amplifier, sirius and emergency telephone etc is located. I have absolutely no sound and have bought Fibre option loop bypass cables to test each component if I can find them. Why did mercedes eng made everything so complicated. Battery under the seat, electronics under the carpet. |
