How to turbo/super charge an R500 ??
1998 ml320 with lift, dirt tires and rust !!!
Hi
So, like my R500, find it far more responsive, dynamic to drive then yhe wifes bluetec R350..... Wondering still, cause im kind a found off the odd sleeper car thing, could there be a way, jas that be done already, to put whether a supercharger or a turbocharger on my r500 v8 ???
Actually thinking about something low boost not to change snything into the engine nor gearbox.....
I know, there are issues, taping into an oil line in and out for the turbo, then custom ( are som for sale as kits ?? ) manifolds for the turbo, some way to set the wastegate properly, ect......
So, any inputs would be greatly apreciated......thanks a Lot
Yes... I thought of the same and actually plotted it out with a mechanic. Would need one small turbo after the cats and feed it back into the intake. Has to be under 6psi boost to stay under 500hp/500tq to make sure your transmission can cope. Total cost was about 5k.
Might be cheaper to buy a 55 amp engine and retrofit it actually.
