Car stalls when air suspension compressor starts
BUT!!!!!! After almost one month of trials and errors, I have discovered that the fusebox was the issue.
So! Open the hood, on the right hand side(passenger's side), should be a fusebox. Open the lid, you will see the relays, modules and fuses. Try to remove that holder from it's plastic case. Underneath that holder is a copper strip that connects various. Check if that strip isn't melted/broken/cut/damaged. In my case that was the problem. Replaced the holder and it worked!
OR there is a quick fix! Remove the plug from the air compressor! But no more adjustable suspension, but at least your car will be running again.
Best of luck!!!
