R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Plugs??? Should be easy!!
Old Mar 16, 2018 | 09:13 PM
efzauner's Avatar
2005 C240 2011 R350
Just pulled a plug from my 2011 R350 and the plug says Y7MPP33
RM European and other parts says YR7MPP33
Puzzled, seems it is a resistor plug while OEM is non resistor. Yes I know that means the connection from the individual coil is probably resistive... etc.
Even the Bosch site has no reference for the Y7MPP33 and says YR7MPP33
Old Mar 17, 2018 | 10:21 AM
auto385's Avatar
2015 Cadilac Escalade ESV, 2010 MB R350 Diesel
just use the YR plugs. In the aftermarket, that's what they do.
Old Mar 17, 2018 | 04:57 PM
efzauner's Avatar
2005 C240 2011 R350
a local parts shop had the NGK in stock. just by luck.
Old Apr 13, 2018 | 05:54 PM
lkchris's Avatar
'10 CL550, '12 GL550
Mercedes dealer has the correct nonresistor plug.
Just remember that Bosch USA might as well be a completely different company from Bosch Germany and has indeed shown an indecipherable tendency to want to sell resistor plugs here. Those would be the wrong plug. The expectation that a USA parts operation can provide correct parts for Mercedes is dubious at best.
FWIW you can search the correct part number on eBay and you may find some. I did ... guy sold his car before he got the plugs changed. Correct plugs in Mercedes boxes, Mercedes star on the plugs. Half price. V8
Old Apr 14, 2018 | 10:12 AM
efzauner's Avatar
2005 C240 2011 R350
thanks for this info.
but It is moot... and too late for me. at 20Kv spark voltage and miliamp currents, a 5k ohm resistance will provide a few dozen volts drop. irrelevant.
The R plugs are made in Germany anyway. Not sure where you get your conclusion about German vs US Bosch
Old Apr 17, 2018 | 08:12 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Hi there,
Would someone please let me know what is a good, or the best, option for V belt makes, OEM vs after market. I have 2 MLs, 350 and 500.
