R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Facelift engine options?
Old Jul 22, 2018 | 12:27 PM
trinitrom's Avatar
Interested in owning
Hi team,
Newb here, looking into these big wagons for hauling a small family. We mostly drive for 1200mile road trips to see our family a few states over.
I'm looking at '11 and '12 R's and have found a local seller who has a '12 Blue Efficiency with 100K. any reason I would favor this over an '11 with less miles?
Is there a breakdown somewhere on the engine options that came in these cars?
(I'm assuming facelift means 2011 or greater?)
EDIT: I should add that I'm seeking a gas-fired model.
Old Jul 23, 2018 | 06:21 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
Originally Posted by trinitrom
Hi team,
I Dont drive an R and from browsing this thread not that often i dont know what is the biggest issue for the car is. Regardless, for both i would do two things, a)Car Fax/service history and b)Have an independent mechanic look at for any potential issues that can come down the line.
Old Jul 23, 2018 | 08:17 PM
dyun1dyun1's Avatar
2008 e350 Wagon
Hi team,
I had my EGR blow up with along with something related to my exhaust which overall wasn't to expensive. Then my manifold needed to get replaced along with my sunroof. I was looking at 8k or repairs just for that. But the car was such a pleasure to drive. If it is just for road trips, I would lean towards the Diesel. It would perform great on the highways and high speed. I believe at that year you basically have the 6 cylinder gas vs diesel engine. You can find plenty of folks talk about the upkeep on the OM642 Diesel engine and my go with the gas engine. You may find a v8 R550 though I believe those are extremely rare.
Anyway, I am in the same boat as you, since I am looking to get back into a R-Class for a family trip mobile.
Good Luck!
Old Jul 24, 2018 | 06:58 AM
CedarMtn's Avatar
2011 R350 BT
Hi team,
Yes, the 2011 and later models have the “facelift”. In North America there were only two engine choices: The 3.5l V6 gas or the 3l diesel. Depending upon where you are located one may be harder to find then the other, Eg: I’m in Canada and the majority sold were the diesels, so V6 gas would be harder to find.
There were no significant changes between the 2011 and 2012 - pretty much identical cars with possible exception of how MB packaged options.
Old Jul 28, 2018 | 10:40 PM
Lioninstreet's Avatar
06 SLK55 AMG, 12 R350
Not entirely true. The biggest difference between the two is the '12 got a new gas motor (m276). "Blue Efficiency".....
BTW, All kinds of horror $tories on the Merc diesel's on MBW. Since I'm not a gambler, went with the gas version so I could spend my extra money on something else...
Old Jul 29, 2018 | 06:05 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Good Luck!
Wasn't this a Canada only special edition?
Old Jul 29, 2018 | 10:45 PM
Not sure about Canada only on the R550 but it definitely wasn't released in the states. I think it was MY 2008 only. But then I also heard they were sold up in Canada in 2013. There are one or two guys here on the forum who are R550 owners. Maybe they will jump in.
I don't think the motor was the infamous m113 V8 either. I seem to remember reading somewhere it's a m273, sharing similar engineering as the 2006-2011 R's m272 6 cyl (without the balance shaft). Same variable length intake layout, and 4 valves per cylinder, just with 2 extra cylinders added.
Old Aug 23, 2018 | 08:52 PM
fearzum's Avatar
R550
Own 2008 R550 with 5.5l engine. Same engine as in the E550. 192000km, no issues.
Old Aug 24, 2018 | 07:08 PM
efzauner's Avatar
2005 C240 2011 R350
Correct the '12 had blue efficiency. you will get better gas mileage. But in the end it may be a wash. how much milleage difference?
i have a fully loaded '11 gas and am very pleased with it. Changed the alternator and rear air bags.
if there is lots of salt on the roads in winter where you are the blind spot sensors will go... expensive to replace. but check for hidden warranties with your dealer.
Old Aug 26, 2018 | 02:18 AM
dinfung's Avatar
2013 R350
I have a 13 gas. R-class was for sales in Canada till 2013. The engineer been great, had mileage isn't too bad considering the weight and size. My forms is a service manager at a local MB dealer. He told her to buy had model as diesel will have more problem over all.
