R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Alignment Specs ????
Old May 10, 2019 | 07:32 PM
BenzBallin's Avatar
R350 2008 4Matic Gasoline
Im having a hard time with Alignment...Aligned twice already but still have this stupid pull to the side and notice inner wear of tires...Anyone have correct Alignment specs ??
Old May 11, 2019 | 09:45 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Check your ball joints control arms and sway bar endlinks for issues. Tie rod ends too. Give everything a good shake whilst on a rack and look for clunk's or movement.
Also check your struts too if they are leaking.
Chdck these as they are common issue .
Old May 12, 2019 | 08:32 AM
BenzBallin's Avatar
Ok Thanks, ..
Old May 12, 2019 | 11:28 AM
efzauner's Avatar
2005 C240 2011 R350
normally the shop checks this stuff before they do an allignment!
Old May 12, 2019 | 07:32 PM
kombifan's Avatar
Is the mb dealership doing this alignment?
If not. Try them.
Old May 12, 2019 | 07:33 PM
kombifan's Avatar
Ok Thanks, ..
You asked.......
These are the main root causes that can cause a bad alignment.
Old May 12, 2019 | 08:21 PM
BenzBallin's Avatar
If not. Try them.
Yea ima have to, ..those as*#h0l*s are asking 250 but im goin this week...Fu*!k it"
