R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Engine swap
Old Sep 23, 2019 | 10:56 AM
JPAMotorsport's Avatar
r350
Engine swap
Will an engine from an ML work in my R? Some say yes Mercedes says no, nobody can tell me what is different?
HELP PLEASE
Old Sep 25, 2019 | 05:31 PM
houseofdiesel's Avatar
2008 R320 CDI, 2006 smart fortwo cabrio, 1983 240D, 1982 300SD, 1980 300SD
Short answer probably no. It is not simple. Sometimes the turbo was unique to each model (OM642) and there are part numbers for each. Other times it was ecm tuning was different. Location of certain components.
Question is, do have the time to make it work? It most likely will work but with a lot of time spent swapping unique parts back and forth (engine mount arms, accessories, sensors, harnesses).Sometimes this can add 20-30 hours to the job and if your paying a shop forget it.
Old Sep 25, 2019 | 09:01 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
Yes it will fit the ml and r class share the same basic floor pans
Old Sep 27, 2019 | 11:02 AM
r350
So I looked at the ML pan vs the R pan it certainly would require swapping the whole lower aluminum housing and metal pan section. It is just an expensive gamble bidding on a wrecked ML if there are larger complications. #hatingmyrclass 🙄
Old Oct 1, 2019 | 01:47 PM
Same oil pans I’ve done the swap previously
