DIY Crankshaft Position Sensor Replacement P0335
I decided to replace this part myself. It cost about 40 bucks on fcpeuro for the oem MB sensor with the OE Bosch costing about 25. The sensor is a pain to get to.
I consolidated the resources I used to get the job done below.
Picture of the sensor location at the back of the engine:
https://mbworld.org/forums/attachmen...cement-cps.jpg
Video of how to replace it:
Good writeup on it as well:
http://www.classicjalopy.com/2019/04...sition-sensor/
In my particular case, I did not remove the MAF as I was able to get my hand down there and unscrew the T30 screw for the sensor. It WILL require you to put together a set of extensions to get to the screw. In my case I used two 1/4" extensions and two swivels.
The most useful thing I had is an endoscope that I bought from Amazon for like 25 bucks. I was able to stick the camera down there to see what I was doing since you are blind otherwise. I would highly recommend getting one for the job since its cheap enough and makes the job a lot easier.
You will get some cuts on your arms so wear something that can protect your skin which is not too thick.
Anyway, hope this helps someone out here as I didn't see many other resources on this.
