R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Electrical power loss at 12v jumper terminals
Old Jun 12, 2020 | 06:48 PM
GLO's Avatar
GLO
W205 C250BT & R320cdi-L V251 (sold c220 cdi Elegance)
Hi, hoping someone like an auto electrician can help me troubleshoot this electrical problem.
My 1180CCA rated battery reads half that when tested at the engine bay jumper terminals.
When tested on the battery terminals it reads 1100CCA.
As a result (and whilst its winter in Australia) its finding it hard to crank over, especially in the mornings.
Any tips would be appreciated.
Old Jun 13, 2020 | 05:17 PM
chassis's Avatar
2017 GLE350 4MATIC
How old is the battery? It sounds like it might be time to replace it.
Measuring anything at the jumper terminals doesn't indicate battery condition. Measuring directly on the battery is how to measure the battery. If the engine is slow cranking I would replace the battery, and the auxiliary battery while you are at it.
Old Jun 13, 2020 | 05:25 PM
GLO's Avatar
GLO
The battery is only 6m old. That why I took it back to the battery supplier and had to remove the battery after the engine bay terminals showed 500CCA and that's after charging it for 2 days.
They are the ones that said it tests fine out of the car!
