Leak between air compressor and valve block
Hi
After performing the airmatic tests with star diagnostic i got info of leaking between compressor and valve block.
it cause often activation of compressor.
The short line of air house doesn't shows any leak .I inserted a new conectors on both side and leak is still there.
Is anyone has a similar experience because my conclusion is to replace the valve block.
Struts and everything else hold the pressure just fine.
Can valve block leak itself?
Hi
