R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Misfires
Old May 2, 2021 | 02:51 PM
M Rehman's Avatar
2008 Mercedes R350
Misfires
2008 R350 base model.
I just replaced the Manifold runner actuator as the actuator was broken and I was not passing the state inspection.
I bought the URO actuator kit, removed the intake Manifold and installed everything back up.
When I started the car, it started misfiring on 6, so I removed all Injectors, cleaned then and put them back together.
Still misfiring, I replaced all 6 new spark plugs and the misfire in number 6 remains.
I switched around the injectors and ignition coils, still number 6 is misfiring long with 5 now.
Totally not understanding the problem. Can it be an electrical problem? I rechecked all wires to ensure all connectors are connected, at my wits end now. Please help.
Old May 5, 2021 | 11:51 PM
ODIOUS's Avatar
None
Do you have the Engine Crankcase Breather Hose plugged in very well?
I forgot to plug mine up (to the top of the manifold) and the engine sounded like it wanted to die when I started it.
Old May 6, 2021 | 05:48 PM
lkchris's Avatar
'10 CL550, '12 GL550
Many folks assume “misfire” means an ignition problem.
if MAF specifies a fuel/air mixture that can’t be ignited, that’s a misfire too.
if a cylinder has little to no compression, a misfire is likely.
etc.
