Hi,
I have been advised to fix both left and right front lower arm bush as it is leaking/cracked including the CV joints. in fact I already bought the parts but I've been advised by mechanic to change the whole control arm as it will be cheaper from the labour perspective. Do you know if we can buy the front left and front right whole control arm? will it include the CV Joints as well?
Is there any part no for the whole front control arms ? I have been browsing around on mbepc but I only managed to get the individual part no of the arm instead of the whole arm part number
http://mbepc.net/1/fg/r/63u/251126/0/33/015#gsc.tab=0
FOUND IT
A251 330 19 07 / A251 330 15 07 /A251 330 13 07 - Control Arm - Bottom Left
A251 330 20 07 / A251 330 16 07/A251 330 14 07 - Control Arm - Bottom right
FOUND IT
did you solve your problem
I am also looking at replacing control arms or bushings... looking for bushing press tool
thanks
thanks
thanks
Yeah i did, i didnt need to replace the control arms. Just the bushings. If you are in sydney area, i can refer you to my technicianOriginally Posted by efzauner
did you solve your problemI am also looking at replacing control arms or bushings... looking for bushing press tool
thanks
