Prop shafts torque spec
Would like to know if anyone could help me with finding the torque spec (preferably in N/m) for the propeller shaft of a w251 4matic, the bolts should all be M10x45.
Picture attached components: *15/20/10
Thanks in advance
Francis
your bolts. # 15. is 40Nm + 90deg New bolt required. Note discrepancy in spec BA41.10-P-1001-01G between 2 pages.
Your bolts # 20 is 64Nm see BA41.10-P-1005-01G
May I ask what you are doing?
Note the tightening procedure
As for the torque spec, correct me if I'm wrong, but for the front/short shaft this seems like the correct tightening setting
Relatively to my first image (20) should be BA41.10-P-1003-01G and (15) should be BA41.10-P-1004-01G, bolts are the same so should have same spec (this is an assumption not a statement)
Nevertheless thank you very much, I'll try to keep this thread updated and hopefully I'll resolve the issue.
Regards
Francis
I try my best! May I suggest getting a subscription to some shop manual service. its a great investment over many years.
Note that there are bulletins about prop shaft/ drive train vibrations. How the system gets stressed. and you need to releave stress by loosening and tightening bolts, plus the shaft also has to meet specific angles.
to drop the "rear" one.Also I'll invest in one of those manuals.
I will update the topic as soon I get the parts delivered to Italy and installed.
