Help with possible water in fuel tank from car wash
So far all I've done is bought a bottle of Diesel 9-1-1 and added the appropriate amount for 20 gallons, hoping it will bind up the water in there. But what can I do to prevent a complete disaster at this point? Do I need to replace the fuel filter? Dump it out? It looks like maybe the fuel filter has a fuel/water separator, or at least a WIF sensor - the core down the center with some kind of screw-top up top, I think this is a "type 01" fuel filter, which I changed out when I got the vehicle about 20k miles ago. What would I do with this - take that whole core out and dump just that out? I see a few videos about Sprinter OM642 engines that have an add-on hose off the filter with a bleeder valve and then you run the fuel pump in key position 2 to bleed the fuel, but I don't think the R320 has this hose. Would I hook a hose to that screw-top on top of the WIF sensor, twist it open, and then try to bleed the fuel? I see nothing online about the point of this screw top.
What kind of problems would I be looking for, and if we had them, for how long should I be looking for them? Would running through a quarter of a tank and then refilling be a good indicator that we survived this accident, regardless of whatever measures I take to try to get the water out?
