How to get R350 in to Neutral with dead battery
R350
battery is dead and i need to roll car out of garage.. i can not charge or jump battery as its dead.. i can not jack up car as its in garage with about 8 inches on each side... i cant open passenger door to change battery... what do i do??
Received 1,005 Likes
'99 and '05 E55 AMG
Check your owner's manual first and then start searching the internet to include YouTube for solution to your problem. Usually on the shift module there is a spot where you can insert a rod such as ink pen which will then press down the release lever so you can move the shift lever into neutral. Does your car have any jumper points under the hood to which you can attach a battery starter pack? If yes, use that to jump start your vehicle then back it out so you can get to the battery under the passenger seat. Remember to not have the key fob in the ignition switch when you attach the battery starter pack! I've only worked in an R350 one time under the passenger seat and it was a PITA.
R350
this car has the electronic shifter on the steering wheel column.. so no way to put a pen in to move the lever... i have tried a jumper pack to start car, no luck, i have tried to charge the battery with a smart charger, no luck, i have tried to jump off my bmw no luck... i cant change the battery.... what else can i do??? how can i roll the car??
any other ideas???
any other ideas???
