R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Steering Wheel Becomes Very Heavy
Old Jul 27, 2023 | 05:26 PM
hujirong's Avatar
R350 Bluetec
2012 R350 BlueTec, this year the steering wheel became a lot more heavier than before. There is no code, no message, nothing can see.
I had the same problem with a 07 X5 4.8i. Can't find anything wrong obviously. Lubricated all joins, etc. Didn't change.
Is the motor become weak? Where shall I look into?
Jirong
Old Aug 11, 2023 | 03:39 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Is it heavy for the whole 360 degrees of the turns or just for part?
Old Aug 11, 2023 | 09:11 AM
hujirong's Avatar
R350 Bluetec
whole 360 degrees, thanks for helping. I am wondering if the electric motor gets weaker over the time.
Old Aug 11, 2023 | 01:08 PM
Tsumi's Avatar
2006 R500
The power steering is driven by a pump on the engine. Typically this pump going bad is the reason for hard steering. There can also be air in the system, but if there was air in the system it probably damaged your pump. There's also the possibility of the steering rack wearing out.
