Drivers door unlocks by pulling on OUTSIDE handle twice
My drivers door unlocks twice when pullng on the handle from the outside. From what I'm aware, this is only supposed to happen when you use the key and turn to the left. In my case, it happens despite the key not even being in the cylinder. My guess is it is stuck in the open position. I tried putting the key in and turning it in both directions to 'lock' it but it doesn't do anything.
Does anyone know what the issue could be? Is it the cylinder that is broken? Spindle (saw this was the case on much older cars)? Actuator (door unlocks and locks fine with the remote/inside buttons though)?
Thanks!
Thanks!
Hopefully you can do same and make it work.
thanks again!!
