Loud Chirp and Buzz from Aux Water Pump
2011 R350 (M272 engine) running rough, engine light appears, pulled P052D code. <facepalm> Auto Zone said it was variable valve timing solenoid bank 2 was retarded - I can't believe that's the terminology.
I disconnected power steering reservoir and removed the oil cooler cover (gasket looked good!) and replaced both solenoids. Everything was pretty easy other than making a mess.
After reassembly and topping off fluids, I cranked up the engine and everything runs smoothly but there's a loud chirp coming from one of the pulleys. It sounds like it's coming from the water pump and the aux water pump buzzes loudly when it kicks on.
Any ideas what I could have done that would have caused that? Would there be air in the system somewhere now? This is a real head scratcher for me.
