R-500 Power Steering Problem
The first mechanic said it scanned for faults which showed a SPS solenoid fault. Upon inspection they found the solenoid is leaking oil and recommend replacement.
The second mechanic is saying the car needs a rack and pinion assembly.
Aside from the price difference it seems like 2 different problems. I'd hate to spend the money only to find out the problem isn't fixed. Any help or suggestions would be appreciated.
The knuckles at the end of the steering column seize and make steering hard. Is it tight for 360 degrees. Does it occur all the time or just some?
