The slow road to my new R500
I'm curious about the AUX input in the glovebox, as I never found it. There's a 6-CD changer and a socket, which I think is for an iPod. What kind of AUX input is yours, if I may ask?
I see that you also have a CD changer, why don't you try playing a CD to test your loudspeakers (and please the boy)?
I wonder if there is a way to remove the CD changer unit and use the free socket for some Bluetooth capable device...
I remembered though that my Audi Allroad came with CDs in the changer and I left them in there! Started off with some Strauss and tried an Alternative CD Mix they had as well.
Sound was good on some of the classical but certain songs and the alt-rock stuff was not great so I'm thinking it's Center speaker up front or the subwoofer itself.
I was also thinking about removing the CD changer I'm sure there's a way it has a bit of wiggle to it so one day I'll investigate pulling it out even just to have more storage space.
You'll need one of these to remove any audio component without ripping out the MOST system from the car: https://a.co/d/ivNvOpX. As I recall there can be up to 4: the amplifier, head unit, CD player, and bluetooth phone unit.
Further testing and sometimes it's got some distortion on certain songs but it really feels like it's mostly on the bass line the speakers themselves don't seem to be crackly.
I wiggled the connections to the sub under the rear floor and made sure it was closed tight and for a whole ride to daycare pickup it was fine but this morning was not great at times again.
If it does happen to be the head unit that's fine I have a Sony XAV-AX3000 sitting around to slide in there, just ordered the trim kit on eBay for only $120 and the MOST adapter on amazon for the same price.
Head unit swap out should be quick and i'll just have to see how the quality is. I have a backup cam, dashcam and subwoofer to put in but I'll do that later.
Are there any other adapters or things to add for like steering wheel controls? I remember having to get an adapter on my WRX back in the day for the steering wheel controls to work on the new head unit.
Same thing with the subwoofer. I might just replace the existing sub since it's in the trunk area already but has anyone added a subwoofer on top of the HK system.
I did this on my BMW that also had HK Logic7 stereo and there was a special adapter some guy made online that basically was a 3 way splice with the right harness connections to tie in the correct wires for the sub cnonection.
eBay and Amazon deliveries will be a week or two unfortunately. In the mean time I need to get a wheel speed sensor and airmatic valve conntrol box to fix my ABS and low front end
Trunk subwoofer is a 6.5" 2 ohm speaker; I believe it's actually the same speaker as used in the doors, just in an enclosure so it can give more of an oomph. If you use an aftermarket 4 ohm speaker, you're going to have to find a separate way of powering it.
Steering wheel adapter will definitely be needed, but not sure what would work. The Android unit I ordered had the adapter and programming built in already so I didn't need to mess with that.
Good for troubleshooting later potentially but for now I'll swap the head unit and see where I'm at. There's always the chance that the wiring got banged around the previous owner(s) put in a radar, they had a crazy big rear view mirror with reverse camera screen built in, plus there's a cutoff switch to watch DVDs while you're driving already. There's another little transmitter with a blue light at the top of the window dead center I don't know what that is either.
I do believe the subs I had were 2ohm and I'm not sure I'll keep them either way. That's a future project hopefully in the summer when the weather is nice to put in the subwoofer(s). I may end up selling the enclosure I made with the speakers as i'll need to find a good spot in the back for one or two speakers and make an enclosure to fit, it was a fun project on the old BMW I wouldn't mind doing again.
I may just end up removing the spare tire and making an enclosure to place there. We have roadside assistance and I was reading online that the airmatic gives you grief when you try and jack up one wheel since it's always trying to level the car and you basically have to take off the battery to change a tire?
Seems more trouble than I would want to go through roadside so the spare is largely going to be useless I think.
Any other good spots anyone has done/heard of to place a speaker without sacrificing storage space?
Giant empty cavity with the exception of the HK system amp underneath the driver seat. Just a bit of a pain to get to.
I could conceivably remove the HK subwoofer and just extend the wiring to a single like 12" sub in a circular enclosure where the wheel sits.
Decent access to solder the wires as needed so theoretically it should be easy enough without running any new wires from the head unit...
Turns out one of the wheel speed sensors is shot, every once in a while after pulling off a curb the ABS triggers briefly
The front end is also lower than the back but not super low, that ended up being the Airmatic Control Valve Block thinking the front end is at Max pressure when it's not.
Wheel speed sensor + control block ordered and arriving shortly to fix that up.
I've also noticed twice at a stop light there's a bit of rough idle, after continuing to drive it's fine and it rarely happens.. not sure what that could be?
Additionally I've had a few times the car seems to get stuck not going higher than 4th gear. Not usually a problem as I can do 100km/h in 4th no problem but slightly concerned I may have a second vehicle in a row that could need a TCM replaced.
Maybe it just needs a transmission fluid flush? Probably hasn't been done but can't be certain unfortunately.
I also saw a random Facebook post in a W251 group that talks about water leaking coming in under the wipers somewhere that could cause issues with the water buildup. As my old Audi had a similar problem with the drain hole for the sunroof which caused a failed TCM thanks to a puddle in the passenger footwell
If I can get ahead of a problem like that I definitely want to.
I can manually close the tailgate just fine as well however the button only briefly worked.
I assume it's just the button itself/wiring to it I hope?
I also notice that sometimes more than once the hatch autocloses/latches while driving. Does the car do this more than once usually after you take off? I assume when the doors autolock it would ensure the tailgate is latched also.
Never have a light on indicating the hatch isn't closed or any interior lights staying on so I assume it's functioning as normal.
Drain holes for the cabin air intake can get clogged and lead to water leaking and pooling in the battery compartment beneath the front passenger seat. Front SAM is also located there I believe. Common issue on the W251, W164, and X164. It's almost absurd how many issues carry across the three models.
Tailgate should only latch and lock once. I would be concerned about water damage to the tailgate control module.
VIN shows early 2006 Build Date but Mercedes Canada at one point confirmed it's a 2007.
Drain holes issue was that under the wipers? In that area somewhere I think I remember reading?
Car inside is quiet, dry as a bone and no signs of water ingress anywhere so I can't imagine it's an issue. Yet
The latch I also assume is just something on the rear hatch door itself, it opens automatically just fine but the button to close does nothing 90% of the time.
Transmission has largely been fine as I drive it daily the 4th gear thing hasn't happened in weeks, most concerning is the ABS sensor which made it almost impossible to get up an underground parking lot ramp it was triggering the ABS so much. Turned off ESP and sat for a bit and it was fine, the part I ordered apparently was wrong so I need to get a new one.
Don't want that to happen again, was on the way out of swim class with the kids and the wife freaked, got her mom to come and tail us on the way home to be safe
The car is pretty dry all over so I'm not too worried though I'll look around when the weather here is better and I don't have so much on the go.
Lots to do we've got an easter egg hunt planned for a bunch of kids at our house. Hopefully after that i'll have time to put in the stereo and stuff.
I have the optical decoder box and the trim kit ready to go so shouldn't be too hard unless I have to take apart harnesses to splice wires.
Then I'll finally take some pictures to post
But thankfully Easter went swimmingly and since I had an extra day off Monday I got to install the stereo.
I was just doing the head unit install so no crazy wire running for camera or anything. I found a YouTube video that helped me identify some wires so getting the Battery line and the Ground was easy but getting an ignition switched power for the Accessory?
Sonofabish I could not for the life of me find any confirmation about the JDM head unit pin outs so after many hours I gave up and got a new 12v tester and found ... nothing. I could not see any switched power to use in the stock head unit which seems ... weird.
Thankfully since it was JDM there was a toll card reader under the dash they installed which I binned and used the wire set from that which pulled back to the head unit area without too much fuss. Voila an extra ground and switched power.
It seemed to take a bit of time for maybe the HK system to recognize the decoder box or something I dunno but there wasn't sound for a bit then there was.
I thought everything was set until after turning off the car then next time I came in, no sound. I thought it was my temporary splice connection using a wire nut so I got some butt splices and crimped everything back in to place.
Sound came back but again not for long. I dicked around last night wiggling connections and eventually got it again.
This morning no sound once again despite nothing being touched and the car not moving. As I was driving in our shipyard going the stupid 10km/h speed limit I was able to pop off the fiber connection, plug it back in to the decoder then sound came back right away.
So clearly it's fiber loop related or the decoder box is just bunk inside? I might be able to return as it was amazon, or get a replacement but that will take a long while as it came straight from China.
Maybe I need to get that loop tester to see if taking out the CD changer maybe helps? I don't think it's a wiring connection issue, the head unit turns on and off with ignition properly and everything works just no sound output...
Yep, no switched power for the radio; it was turned on by CANBUS. The Android head units have a CANBUS decoder box for this purpose. I believe the decoder box also provided a reverse signal, steering wheel position for reverse guide, steering wheel button control, and also a signal for which door was opened so it displays on the screen.
The decoder I got just had the fiber In/Out slot with a harness clip plus a connector that had a Ground, Battery, Accessory and RCA cables.
There is an existing backup camera and I have an aftermarket one already in case that one sucks but should the MOST decoder box also have more wires for other stuff?
The camera on the car actually fed to a large rear view mirror with a small screen section so presumably there's a wire somewhere I can bring down to the head unit area that can connect to the Sony unit.
I could care less about steering wheel controls for the stereo but definitely would want reverse position/steering line guides on the backup camera. Is that a separate harness or part of a MOST decoder in which case I should try another model of decoder this time...
Unfortunately I have to wait for the seller to send me a new decoder box so not fully clipping everything back in to place as I have to fiddle every time I start the car to get the sound working.
Now since it was a JDM head unit it took some sorting to figure out. There was a 4 wire harness in the back with a couple of medium gauge wires. One was Ground and one was Battery. Not sure the last one but it wasn't Accessory.
One of the next steps will be replacing the subwoofer in the back. I'll have to build a new box etc so that will take a while but I'm sure some of these wires Ill need for subwoofer connections?
Also what in the dang heck is this seems like wires go from the front of the car and split to the subwoofer above and this unit.
I also need to clip the cover off of the overhead lamp unit area as there should be a wire that connects to the existing backup camera. I checked the old clip on mirror and there's a very small like 10pin round connector the other end should be up there...
Heres a pic of our r500
