R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Help With Turbo Replacement
Old Dec 22, 2024 | 10:11 AM
hankthebald's Avatar
I have an 2011 R350 Diesel that I need to replace the turbo charger and I have zero experience with this setup and am fairly new to Mercedes.
I was wondering where I could find a procedure for replacing the unit.
It looks like turbos going bad are a common problem and that replacement turbos run several hundred to several thousand dollars. I was wondering who makes a good quality unit that will not break the bank.
Thank You
Henry
