R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Headlight adjustment?
Old May 17, 2025 | 03:41 AM
TerjeG's Avatar
2011 GLK 220 CDI
I have this 2007 320 CDI with bi-Xenon headlights. The headlight on the drivers side is aiming way more down than on the passengers side. The only adjustment screw I can find is to adjust sideways. I've read that up-down adjustment is an automatic function depending on the car's load, but what to do when I have this issue? I've checked that the bulb sits correctly.
Old May 17, 2025 | 07:35 PM
Tsumi's Avatar
2006 R500
There is a second adjustment below the top one, if you found the top one. That one adjusts height. If you didn't find the top one, that one normally has a cover on it. You have to pop off the cover to get to the screw.
