Seattle R63 Build/ Photo Thread
As you know the R550 has the 5.5 V8 found in the S550 which has 382 hp. What makes this model interesting is that they cancelled US V8s after the 2007 model year and the 550 was never introduced here. We only had the R500 and R63.
XXGenericSNXX:
Very cool to see an R550. I can't believe there is an "R-Class" that is actually rarer than your R63 - at least in the USA. While it won't hustle nearly as well as your R63, the 5.5 V8 with 382 hp should move the R550 nicely. And are those 20 inch or 19 inch rims on the R550. I am guessing 20s but they look small relative to your 21s?
Thanks for sharing your meeting.
Kind regards,
For 2006 and 2007 these rims came as an option from the sport pack as mentioned above.
On the 2008, the AMG bumpers became standard and these 19" wheels became optional.
Yes quite odd the R550 seems even more rare than the R63. I suggested that I should trade with him and give him cash. =]
Can i ask where you purchased the euro rear wheel arch extensions? do you have a part number?
Also, for your Wald front bumper, did you need to buy any additional spare parts (from MBZ) that you couldn't pull off your stock bumper? In other words, between the two bumpers, you had everything you needed for the install?
Many thanks
Flare part numbers with an approximate price that I paid at the stealer:
Left Fender Flare Upper 251-880-17-05 66.82
Left Fender Flare Lower 251-880-15-05 72.38
Right Fender Flare Upper 251-880-18-05 66.82
Right Fender Flare Lower 251-880-16-05 72.38
The Wald bumper had everything I need. However, they had to tear apart a lot of the stock bumper to get it to mount to my car. They had to reuse the parktronic brackets and headlamp washer brackets. They also had to remove the rivets of the bracket that holds the bumper skin in place and transfer that to the Wald. The center bumper is reused from your stock AMG bumper. The headlamp washers and parktronic sensors are reused. So if you don't have the headlamp washers or parktronic from the factory you'll have to figure something out. The body shop charged me 16 hours of labor to transfer all of that stuff over from the stock bumper to the new one.
If you do get the Wald bumper, do yourself a favor and get the European parktronic sensor covers for the corner lights as it looks a lot cleaner. If your car doensn't have parktronic, just sand and paint the orange markers body color.
Wald bumper is ordered through Jonari- just an average experience.
Those Euro Parktronic corners are also from the stealer:
Bumper Joint Cover Right (Parktronic Corner Cover) 251-885-10-23 28.45
Bumper Joint Cover Left (Parktronic Corner Cover) 251-885-09-23 28.46
Best of luck and I'd love to see pics of the process!
BTW bumper took 10 weeks to arrive from Japan and note I skipped on the rear bumper which Wald also makes.
When do you plan on adding the 65 tips? Was curious to see how it looked, haha.
Any long tube/tune/exhaust work in the plans?
No plans for any go fast parts. The ECU tune for the M156 isn't very good, only about +10hp which is about a 2% increase in power. Not really worth it. Luckily the exhaust makes a nice sound as is and can actually be heard in the car.
Red calipers
Matte black headlight housings
Carbon fiber diffuser w/ 65 tips
Alcantara headliner
Alcantara door panel inserts Brabus style
Anyways this last update is the Ventilated Seat retrofit thanks to MBenzNL who provided all of the parts and instructions the install went fairly smoothly. The whole kit is pretty much plug and play. The Ventilated Seats were a Euro only option for the R-Class the first few model years and was not available as an option on US spec R63s. I remember seeing an R63 in AMG's headquarters in Affalterbach, Germany in summer of 2006 and it had the vented seats. It's always been something I've wanted.
Here's the parts:
Huge box of goodies from the Netherlands:
Seat Cushions:
Switch Row. I had them send me a switch row with a button for the standalone heater as well. The standalone heater is a separate small gas motor that goes in the engine compartment and will heat up the interior and engine coolant (basically remote start but OEM). Don't think I'll retrofit it but it's nice having a full switch row panel instead of a dummy button.
Wiring harness:
Vented Seat Modules:
Seat back panels with the ventilation grille inserts:
Seat cushions with the fans:
All of the parts together:
Now onto the install. Both front seats need to be removed and the seats have to be stripped to the frame so the new cushions can be installed. The second row driver seat also has to be removed in order to access the false floor which gains access to the control unit. The wiring harnesses are completely plug and play and does not require any STAR coding. The wiring harness plugs into a module under the floor and those wires run to each front seat. The car is already prewired for the vented seats so when you install the new switchrow on the dashboard, everything just works.
Note the multicontour seat bladders:
And once finished everything looks OEM because all OEM parts were used. My seat skins didn't have to be changed because luckily all AMG seats had perforation at that time.
The verdict, it works as advertised. The fans provide enough air to cool the leather around that area and I can feel a subtle breeze on my back. On the seat bottom though, I don't feel as much I think because I'm putting a lot of weight directly down. Nevertheless it's a nice feature to use in the car on warm days.
We did run into a snag on two of the wiring harnesses. The wires were not correctly plugged into the correct parts of the terminals. Because the kit was supposed to be plug and play but in reality when we tried it out and it wasn't, we had to reverse engineer it and test the voltages from the wires and refer to the wiring diagrams provided by the manufacturer. Without professional help we would not have figured that out.
Also we needed some codes cleared so that hte multicontour seats started working properly again (because the car had the seats removed and was started so the pump shut off for fear of overheating itself). So when we reinstalled the seats we had to clear the codes since the multicontour seats were properly put in place. It's nothing a dealer can't do, but a good independent should be able to do the job as well. You just need to give them all of the explicit instructions. Luckily I had some friends that helped me out with knowledge of the electronics of the car
Total time was like 14 hours for two guys. So the short story is get pros to help.
If you need an AMG bumper for the R-Class they're only a few hundred dollars on eBay and have all of the brackets that you need. (R63 bumper is the same as a sport pack R350 bumper)
Here's my car with my friend's modified C63. In the later pictures it's with a modified 135i and slightly modified XF along with the same C63.
As GenericSN mentioned, there isn't a huge amount of options however, Kleemann makes a power kit that outputs ~340hp. Consists of ECU, SS tubular headers/downpipes and sport camshafts.
They claim 305 HP and 278TQ [corrected, thanks Generic] with just the ECU upgrade.
http://www.kleemann.dk/Performance/E...0V6_M272.aspx#
Love the look and the sound. I am still amazed at the scope of the modifications you have undertaken on the car, like the addition of the ventilated seats, as an example. Wow!!
I said it before but I it is worth repeating - I think it is great that the mystical R63 has found such a passionate owner as you.
Kind regards
Btw, have you considered to paint the grill black and left the star and strips chrome? I did it to mine and it looks much cleaner, especially for a black R-class.
