S/CL-Class (W140) Coupe 1994-1999: S500 Coupe, S600 Coupe, CL500 Coupe, CL600 Coupe
CL600 V12 TRANS TUNNEL KEYHOLE
Old Mar 17, 2009 | 09:52 PM
DINGO's Avatar
CL600
Question CL600 V12 TRANS TUNNEL KEYHOLE
I've only had this 1994 coupe for 2 mths and am still finding my way around. There is a yale type barrel lock set into the carpet on the passenger side of the transmission tunnel. I have no key and no information about what it might be. Perhaps some sort of transmission lock?? The car was originaly delivered in Hong Kong then imported to Australia. I think the trans would have to come out to look at it from the underside and I'm not that curious but if anyone knows what this is I'd be most greatful.
Cheers
Dingo
Old Mar 22, 2009 | 09:57 PM
1993_300SE's Avatar
1993 300SD, 1997 S600 Coupe, 2007 S550 4Matic
Cheers
Dingo
Hmm, I will have to check mine and see if I have such a thing.
Old Apr 8, 2009 | 08:22 PM
DINGO's Avatar
CL600
Mystery solved
Just replaced engine mounts, so had opportunity to inspect the side of gearbox from under the car. The unit is a cable operated gear lever lock that appears to be an original factiory install. I believe the car may have been delivered new in Hong Kong to a TAA airlines pilot and I am guessing the car may have been left for long periods in airport carparks and neede this extra security. I wonder if I can get a key made to fit?
Cheers
Dingo
