CL 600 engine noise
Mercedes Cl 600
CL 600 engine noise
I have a 1998 Mercedes Cl600 with 60k. There is a engine noise and weak power. Does anyone know what has caused this? I've heard the oil feed tubes crack and need to be replaced. Does anyone know how to replace these? Or is there another common problem?
Mercedes Cl 600
It doesnt idle to bad. Once you start it, it idles right away and holds good oil pressure. There is a ticking at the top of the motor. There is no check engine lights on tho. What is travel plug sensors?
