Wiper Issue
Wiper Issue
Hi.
The passenger side wiper arm on my S500 got stuck in up position and did not move. I checked the nut holding on the arm and it was a bit lose so tightened it up...wiper starting moving for about 10 cycles and then stopped again.
Checked and the motor and it is turning fine. Seems like the arm and mount are stripped (no grip) on the arm. My question is, do I need to replace the arm or has anyone else have a different solution...like I said the motor is working.
Thanks.
Benz14.
Thanks.
Benz14.
Hi,
Had the exact same issue on the same side (wiper arm stuck in up position). Took my car back to dealer, they replaced the holding nut and bolt. Issue resolved .
To answer your question, try replacing hold nut and bolt.
Jailer114
Jailer114
