S/CL-Class (W140) Coupe 1994-1999: S500 Coupe, S600 Coupe, CL500 Coupe, CL600 Coupe
mercedes se 500 - 1992 - starting problem when warm
Old Dec 16, 2011 | 07:39 AM
noe173's Avatar
c200
hi
I have a mercedes se 500 (1992) - w140
the main problem is that when cold engine starts easily, but after 15 minutes
(engine goes warm) .. engine stops... and will not start again.
I change the
crank pulse sensor,
x2 ignition coils,
check and replaced one fuel pump
fuel filter.
I realised that the fuel supply is shutting off when engine is warm,
as if i spray fuel from top.. engine continues to run.
SO PROBLEM IS THAT FUEL SUPPLY IS SHUTTING OFF WHEN
ENGINE WARMS UP!!
any idea to help please?
more over no dash light are ON... so have no clue
thanks
