S560 steering wheel question
Old Nov 27, 2020 | 06:39 PM
fxst1987's Avatar
s5660
Just picked up a '20 S560. Wanted a '21 build but no luck there. Question: Can the leather steering wheel be swapped for the wood/leather heated wheel? The local dealer seems reluctant to answer the question...
Old Nov 27, 2020 | 07:26 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
not sure. But if its like other cars, there has to be wiring already in the column for the heat. Maybe there is, maybe there isnt. I dont think there is anything else that wouldnt swap since all the wheels have the same multifunction's
maybe check with dct motorsports and see if they have wheel that match and get info from them
Old Dec 2, 2020 | 06:36 AM
carnut1's Avatar
2020 S63 Coupe, 911, BMW 760 2022 SL55 2024 Range Rover
Yes, but you will probably need to get the part numbers yourself. Most dealers will not take the time to search for the correct parts. MB is not as complicated to swap out as other brands, but if you have never done it before, I'd find someone that has.
Old Dec 2, 2020 | 09:07 AM
konigstiger's Avatar
'71 Pinto
Looks like you will need to replace steering wheel and steering column module, code with Xentry (MB diagnostics), and update VEDOC. Need VIN to find part #s.
