Trunk issue
Old Feb 24, 2023 | 02:30 PM
WLB's Avatar
WLB
2026 AMG CLE53 2026 Vistiq
Trunk issue
2015 Edition one coupe. The trunk will pop open as it should however it does not raise and I can hear what sounds like a motor running which I assume is what would normally raise/lower the lid. Also after manually raising the lid I can see the red close/lock buttons are not illuminated. It closes and latches manually. Any ideas?
Old Mar 5, 2023 | 01:23 PM
andymlow's Avatar
2019 S65 Coupe, 2005 Ford GT, 2013 Viper, 2011 Boxster Spyder, 928 GT
Trunk closer
Would check fuses first
Old Mar 5, 2023 | 02:35 PM
konigstiger's Avatar
'71 Pinto
Try normalizing drive unit: Close trunk lid manually. Open trunk lid by pressing driver-side trunk lid open/close switch in door trim and wait until the trunk lid has reached the upper stop. Then hold trunk lid open/close switch in the "open" position for 4 s. May need to several attempts. If this fails, have someone erase stored codes and pull current using Xentry (MB diagnostics) drive unit may need replacement.
Old Mar 7, 2023 | 03:58 PM
WLB's Avatar
WLB
Thanks for the input. Further checking indicates that the noise I hear is the trunk latch working as it should. The problem is the drive unit is not functioning. I believe it is a fuse/electrical issue perhaps not directly related to the drive unit as the two red buttons on the lid and the two interior trunk lights also do not illuminate. I have checked numerous fuses however with no joy. Looks like time for the dealer to sort it out.
