Cell phone holder solution
I ordered this from ProClip.com it’s designed to work with the W217 and W222. u can mix and match the holders after installing the dash bracket, which still allows the 2 vents behind mines work and swivel, not perfect but way better than most. You can still plug 🔌 into the usb in the center console or buy a short flush usb/ cigarette adapter that allows the cigarette 🚬 port to compress as you close the ashtray with usb plugged in, I’m waiting for short adaptor to come in the mail.
When you say the back outlets, are you referring to the back seat area or behind the dash/ vents which is where I was trying to run it but no luck. I will run in to the cigarette lighter once my short UBS/ Cig adapter comes in the mail. The regular USB in the center console sucks if you need a good charge in a short time.
I just got my short USB-A/ USB-C cigarette adapter and it works perfect, it’s able to compress and close the draw with cable charger 🔌 plugged in, here are the pics
May I ask where you purchased the short USB adapter from? Thank
xxnite2632 (06-12-2024)
