S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Wheel offset required for 1990 420SEL.?????
Old Apr 4, 2005 | 05:11 AM
skeet2low8's Avatar
I have two 1990 420SEL's; one is a driver and the other a toy.
I am thinking of going from the stock wheel size to 16", 17" or 18" rims. My question is "what is the original offset and is the same one used on larger wheels even when the width goes up to 8.5"?
Thanks for the help, Carl
Old Apr 4, 2005 | 11:28 PM
braverichard's Avatar
1989 560SEL, 1999 S600, 2005 S600, 2008 S550 4Matic
Stock offset should be anything around 22mm.... generally you'll be fine with any wheels with offsets between 21mm and 25mm. Anything after that and you may need spacers to prevent rubbing, etc.
